Orbi WiFi 7 RBE973
Reply
Nighthawk AC1900 D7000 'connected, no internet'
PassiveInternal
Follower
Hello, I cannot currently connect to the Internet. The internet LED on the router is off, meaning that there is no connection. I I have a modem cable plugged into the DSL port of the router, if that helps.
If anyone can assist, that would be great.
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 3
antinode
Guru
Re: Nighthawk AC1900 D7000 'connected, no internet'
   D7000[v1] or D7000v2?  Look for "Model" on the product label.
Firmware version?  ISP?
> [...] The internet LED on the router is off, [...]
   What about the others?  Visit http://netgear.com/support , put in
your (actual) model number, and look for Documentation.  Get the User
Manual (at least).  Read.  Look for the LED descriptions and
"Troubleshoot".
   Is this a new installation, or a problem with a previously working
installation, or what?
> [...] I have a modem cable plugged into the DSL port of the router,
   What, exactly, does "a modem cable" mean to you?  What, exactly, is
at the other end of that cable?
Message 2 of 3
What about the DSL LED?
Which  ISP do you have?
Is this a new D7000 and first time installation?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 877 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
