- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AD7200 slow, actual, upload speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Download speeds are fast and consistent between online speed tests and Nighthawk app speed tests; however, upload speeds are widely off and inconsistent. Upload speeds within the Nighthawk app are around 25Mbps, but device testing shows wide spikes anywhere from < 1Mbps to 14Mbps. I'm testing from a computer connected by Ethernet and all firmware is up to date. Also, we're paying for 50Mpbs upload from Cox, connect to an Arris modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AD7200 slow, actual, upload speed
what arris modem is it connected to?
Have you tested it connected to the modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The modem is a Touchstone CM8200. I have not connected to it directly. I'll try that today.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Likely a stupid question, but how do I test internet speed connected directly to the modem? I assume that's what you're suggesting - to bypass the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes, check your speed from the modem.
Disconnect the router from the modem and reboot the modem. Then connect a pc to the modem and try it.
See what speeds you get direct connected.
After you do that, you can power the modem down, reconnect the router, and re-boot the modem.
