Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk D700 firmware V1.0.0.34_1.0.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-05-29
04:47 PM
2016-05-29
04:47 PM
Upgraded to this version today and lost access to my isp. In the end I had to downgrade back to V1.0.0.32_1.0.1 and problem went away. I even repeated the process back to 34 and then to 32 with same results. The only thing I noticed different was under version 32 under the Advanced tab setup wizard under select ISP or under Advanced tab, setup, Internet setup, select ISP. In both places my ISP was listed under 32 and then removed under 34. I couldn't get connected to my ISP on 34 under the "other" ISP. I also tried Advanced tab, Internet, Internet setup and used the same settings between version 32 and 34 and they only worked under version 32...... finally got frustrated and left it at version 32.
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-06-01
08:49 AM
2016-06-01
08:49 AM
Re: Nighthawk D700 firmware V1.0.0.34_1.0.1
Hello myhvac
Have you tried to Factory Reset the device after upgrading the firmware? It could be a issue with some old config between the firmwares.
DarrenM
Message 2 of 2
Announcements
