- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk D7000 - Not booting after power cycle
- Mark as New
- Bookmark
- Subscribe
- Permalink
My D7000 modem router was running slow and playing up last night so i turned it off, unplugged all connections and left it for 30 seconds. Upon trying to start it again, the power LED would stay lit with an amber/orange light. I tried holding reset but no luck, have left it off over night and tried again but still no progress. I read online that holding the reset button for 30 seconds, and while holding remove power supply, and then plug in power supply and continue holding the reset button for 30 seconds would also reset the router. After that, the light flashes orange and amber but after restarting the light remains amber.
I connected through ethernet to attempt to get into the dashboard using routerlogin.net, 192.168.0.1 and 192.168.1.1 but nothing worked. I ran ipconfig /all and wasnt getting an ip i'm used to seeing from the router (169.254.78.108)
Any help would be much appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk D7000 - Not booting after power cycle
Sounds like it is dead. If the firmware is corrupt, then the only way out may be to try tftp.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
I'd also check that the power supply isn't on the blink.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply michaelkenward, i followed the link you gave me, enabled tftp and assigned static ip, subnet and gateway but when i try to executre the tftp command while power led is flashing it says 'connect request failed'
- Mark as New
- Bookmark
- Subscribe
- Permalink
TFTP is not the easiest thing to use.
You might find something more detailed out in Google land.
Or the D7000 may just be dead.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This would be the happiest reason.
@michaelkenward wrote:I'd also check that the power supply isn't on the blink.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] enabled tftp [...]
So, you're doing this on some kind of Windows system?
> [...] and assigned static ip, subnet and gateway [...]
To the Ethernet interface? Actual values?
> [...] but when i try to executre the tftp command [...]
Actual command?
As usual, showing actual actions with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
