Orbi WiFi 7 RBE973
Reply
Nighthawk D7000 parental control problems
nicolassp
Tutor
Hello, i observe that when i enable parental controls, i cannot exclude or change parental control level via network map(the options do appear but they have no effect).
For example i set parental control level to medium. Then via network map i change the parental control level to low for one device. The change has no effect since all the devices follow the modem/router parental control level ignoring the override level mentioned.
I hope that it can be fixed in future firmware update if this is the case.
Thank you.
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Nighthawk D7000 parental control problems
Hello nicolassp
Thank you for pointing this issue out I will pass this on.
DarrenM
Message 2 of 3
nicolassp
Tutor
I hope i will get a reply at your earliest convenience when a solution is going to be implemented.
Thank you
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2681 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
