- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk D7000V2 always loses settings after a power outage or the modem is unplugged
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there
I am constantly having this problem. My modem loses certain settings and cannot connect to the internet automatically after a power outage or it is simply unplugged from the wall.
To reset I need to login remotely using my mobile device and reset certain settings.
It's happened so often that I know how to do this quite easily now. But I'm worried this will happen when I'm out of town - I won't be able to explain the fix process to my partner.
Is this a known fault? Am I better off to buy a different modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk D7000V2 always loses settings after a power outage or the modem is unplugged
What are these "certain settings"?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If you are not on he latest firmware, then update to the latest, preferably manually.
Even if you are on the latest,m it may help to load it again just in case a previous update failed to rake and creates the issues you see.
One thing you can do is to create a backup of your settings when they are to your liking. Then, when they get lost again, you can reload them.
If you visit the support pages:
you can feed in the model number and find all the documentation and firmware for your hardware.
