- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X4S D7800 Firmware 1.0.1.16 QOS database
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've just upgraded to the latest firmware, but I am unable to update the QOS database.
Each time I try to do so, it gives the following error;
Failed to download Detection Database. Please try again later.
The database itself is Version: v3.0607.cloud-g0 Release Date: June 07, 2016
If I return the firmware to 1.0.0.48, the update process works.
My 2nd query is regarding the priority you can set to specific attached devices (low/medium/high/highest)
The options I assign seem to reset themeselves after a while.
Logically, I would assume these individual assignments get stored against their respective MAC address, but I'm guessing here, but this reset mean that they are in fact resetting when the attached device's DHCP lease has expired and new address assigned?
Many thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk X4S D7800 Firmware 1.0.1.16 QOS database
Hello hawkerpaul
Have you tried to change these settings in multiple browsers to see if its just a browser history issue or cookie issue?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Darren.
Thanks for the reply.
No, its the same whatever browser I try, so its not a cache/cookie issue.
Any ideas on the 2nd part of my query regarding priority assignments to attached devices losing their settings please?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Hawkerpaul
You could try to go back a firmware to see if its a issue with the firmware and will let you make those changes.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Darren
Could you please confirm if assigned device priority (under the Attached Devices section) is linked to IP address or MAC address please?
If it is linked to MAC address then there is a bug on all firmwares, as the assigned priorites always get forgotten after a fiarly short period of time
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can confirm qos rules do not update on 0.48 or 1.16
edit: error comes up on both, but appears to update to later version on .48 displaying june 07th 2016
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem. I'm using 1.0.1.16 firmware, and I have just restored to factory settings without any success. I still get the message Failed to Download Detection Database, please try again later.
