- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Nighthawk X4S D7800 setup problems.
HELP. Ive just bought this router but the ADSL led stays off even though I have it connected and I get the message no dsl cable connected. There was no adsl cable in the box when i got it (from Amazon) I have tried various splitters,resets ect but still no led light and I can not connect to the net . Is the ADSL cable special in any way? Ive spent hours messing with it and am fed up. Im with plusnet and they have checked my settings and say they are correct but say I should contact Netgear as the plusnet router works fine. Any Ideas or set up guides would be a great help as I dont want to send it back. Regards Alfaromale.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Nighthawk X4S D7800 setup problems.
Generally, no.
> [...] Im with plusnet and they have checked my settings and say they
> are correct [...]
They might be right, but with my weak psychic powers, I can't see the
configuration of the (unspecified) old modem or the new one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Where are you? (Australia by any chance?)
What version is the firmware on your D7800?
If you have not already done so, a search on this forum might be useful:
For example, they would find these:
Re: D7800 will not detect Dsl cable - NETGEAR Communities
Re: Netgear Nighthawk D7800 - Faulty firmware - .2... - Page 2 - NETGEAR Communities
I have seen messages where the local network seemed to use different cables. Hence the "where are you?" question.
If by Plusnet you mean the UK network, then that's just BT with a different badge on the front.
The plug that Plusnet supplied should feed the Netgear modem/router. Just plug it into the right hole on the router.
There is a manual for the D7800 somewhere at the end of this link:
>>> D7800 | Product | Support | NETGEAR <<<
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
