Orbi WiFi 7 RBE973
Reply
Nighthawk ax1800
83or95uchoose
Follower
Nighthawk ax1800
Having problems connecting my new nighthawk router to my existing at&t dsl modem/router. Looking for steps to setting it up thanks.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 3
Re: Nighthawk ax1800
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
You can find the model number on the label on the device.
Begin with the Quick Start guide.
Message 2 of 3
Guru
If you're existing dsl modem/router device is running in router mode, you'll be in a double nat which can make the RAX show as "no internet" sometimes. or cause other issues.
https://kb.netgear.com/30186/What-is-Double-NAT
You can place the RAX in AP mode or configure the att dsl modem router in passthrough/modem only mode. ATT isn't know for their devices performing this properly. Just an fyi.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1025 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
