- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No Internet Lights On - D7000v2 Nighthawk AC1900
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No Internet Lights On - D7000v2 Nighthawk AC1900
@radtech1 wrote:
I am updated to firmware version V1.0.0.47_1.0.1 (The most recent as of today) Does a permanent fix exist?
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will the "Factory Reset" cuase me to lose the setting that I had to enter when setting up the Modem? That process took over an hour with a lot of help from ATT. If this information is set back to default, is there any way to print the entire bundle of setting before I reset?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes.
No, which is a major cause of complaint among users. I use screen grabs to capture key details.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
There is a manual for the D7000v2 somewhere at the end of this link:
>>>> D7000v2 | Product | Support | NETGEAR <<<<
See page 157.
