Orbi WiFi 7 RBE973
Reply
No internet connection
Andy38
Purchased the R8000 Knighthawk X6 and the DM200 modem. I connect up using the wizard and in Netgear advanced "Router Status" the "Internet Port" has a yellow exclamation mark. "Router Info, Wireless Settings 2.4, 5, 5, are all green and the "Guest 2.4, 5, 5 are off.
My ISP is Utility Warehouse and they have provided online the following details to allow me to setup but I have a few issues
1, I cannot find the option for PPPoA only PPPoE
2, I cannot find Encapsulation or the VPI/VCI settings
Utility Warehouse requirements
Standard Broadband
• Connection Type: PPPoA
• Encapsulation: VC–MUX
• VPI/VCI Settings: 0/38
• DNS Settings: Auto or Primary:
Thanks in advance!
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Re: No internet connection
There is a slight quirk with the DM200 in that despite the documentation it has limited router function.
You'll need to disable that before you can start playing around with the settings on the R8000.
There is support for the DM200, including a manual, somewhere at the end of this link:
>>> DM200 | Product | Support | NETGEAR <<<
See the section Disable the Modem’s Routing Features and Use the Modem as a DSL Modem Only.
The manual also explains how to Specify an ADSL Connection With a Login and PPPoA or PPPoE Service.
Message 2 of 3
antinode
Guru
   Where are you looking, on the DM200 or the R8000?
   My grasp on the details is tenuous at best, but as I understand
(cough) it, PPPoA can be configured only on the modem, not on a separate
router.
   How, exactly, did you configure the DM200? Is it in its modem+router
mode, or its modem-only mode?  I'd start with the DM200 only, in its
(default) modem+router mode, and see if I could establish a good
connection to my ISP that way.  When that works, I'd try demote the
DM200 to modem-only, and add the R8000, using the "Specify an Internet
Connection Without a Login" method described in the R8000 User Manual.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Repeat for the other
device.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1012 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
