- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Please Help! Cannot set up N300 DGN 2200v4 to connect to Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@makgmommy92 wrote:
It says on their website that certain speeds can be supported on adsl. I could be wrong about them not using vdsl here.
That message is telling you what the top speed will be if you have an ADSL service. It does not mean that you can stick an ADSL modem onto any service and get it to work at that speed.
If your service is VDSL then it will get nothing through an ADSL only modem. (Newer modems can do both ADSL and VDSL.)
For many services, the fastest you'll get with ADSL is 8 Mbps. Other than asking your ISP, one way to work out what service you have is to see what speed you are paying for. If your ISP says that you can get anything faster than around 12 Mbps, then it isn't ADSL and your DGN2200v4 modem won't work.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Please Help! Cannot set up N300 DGN 2200v4 to connect to Internet
@makgmommy92 wrote:
I have been trying the past few days to set up my new modem router so I can connect to internet.
Not knowing what that modem router is, no one can even begin to guess what you need to do.
If you mean the DGN 2200v4 that is an ancient (2015 or 2011 for the original version) ADSL2+ modem/router. I doubt very much if Windstream uses ADSL2. It is almost 20th century.
Modern Internet is usually VDSL, Cable or even full fibre.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] my new modem router [...]
A DGN2200v4? Who recommended that (not very "new") model?
> [...] My Isp is windstream. [...]
Which type of service are they giving you?
> [...] I followed the directions [...]
_Which_ "the directions"? Some of the non-psychics in your audience
can't see what you see.
> [...] When I hooked my ethernet cable into the lan port [...]
An Ethernet cable normally has two ends. What, exactly did you
connect to what, exactly, using your "my ethernet cable"?
"the lan port"? Which LAN port is "_the_ lan port"?
> [...] my genie gets stuck on detecting internet connection. [...]
Forever? Or is there a "set up manually" option?
> [...] What am I doing wrong? [...]
What are you doing? With what?
> [...] I am definitely not tech savy. [...]
You shouldn't need great expertise for this, but the less you know,
the more important accurate, detailed, precise descriptions become.
(And the less value your analysis may have.) What you did, and what
happened when you did it, are what matter. Vague descriptions of what
might be complex operations often convey little or no useful
information.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] If you are going to be rude and unhelpful [...]
If you won't answer basic questions about your equipment, what you
did, and what happened when you did it, then "unhelpful" may be about
the best you could expect. As for "rude", I don't see what you mean,
but I consider your wasting my time with information-free postings to be
more "rude" than anything else here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@makgmommy92 wrote:
My area has not switched to cable or vdsl.
Are you saying that your ISP still delivers ADSL?
I did a quick search for Windstream and could not see that it used ADSL. (It might prefer to keep quiet about still using tired old technology.) There are various conversations here about Windstream and they suggest that it uses VDSL and other technologies. That's why I asked about your internet service.
Search - NETGEAR Communities – Windstream
So it is probably down to your local network.
Following your reply, I found this:
Can I use my own equipment with Windstream services? | Support | Windstream
Unfortunately, that isn't conclusive either. There are different flavours of ADSL. Bonded for example is one variant that Netgear does not support.
What it boils down to is that you aren't likely to find a Windstream expert here, but the ISP should be able to tell you if your DGN 2200v4 is compatible.
There are still unanswered questions in your first message. If it is the DGN 2200v4 that is the modem you refer to, and if it is compatible with your Internet service, your first step should be to factory reset it:
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
This will wipe out any settings from the previous owner. This is clearly a second hand modem/router. (Netgear hasn't made them for some years, and it is well beyond the 90-day support window, which doesn't apply ro second had devices.)
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@makgmommy92 wrote:
I got through to someone at Windstream that let me know the modem being ADSL is not the issue. It isnt working because my service requires it to be bonded.
That is something I warned you about several messages ago.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I asked "Which type of service", but got no (useful) response. (How
rude!)
For the record:
- Mark as New
- Bookmark
- Subscribe
- Permalink
