- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Please help me choose a better modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
ive had a Netgear DGND3300 working for years its worked flawlesly but the influx if DoS attacks has forced me to use firewall rules to block the IP address doing the attack its worked for months.
a few days ago i reached my modems max amount of blocked IP's (109) i now would like a better modem that allows more IP's to be blocked if i can get one with no limit id be happy
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You keep saying "processed" as if something undesirable is happening. In fact the modem has done the proper thing by identifying it as an invalid packet and blocking it. And it can do this on its own without the help of address filters.
I think this conversation has run its course. I feel that I was unable to convince you that your request for additional address filters for the purposes of DoS protection is misplaced and unnecessary. Hopefully, this conversation will be useful to others.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Please help me choose a better modem
@handy142 wrote:ive had a Netgear DGND3300 working for years its worked flawlesly but the influx if DoS attacks has forced me to use firewall rules to block the IP address doing the attack its worked for months.
Netgear's logging mistakenly described some legitimate traffic as DoS.
If you "whois" some of those IP addresses you may find that they are Google or even your |SP!
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks for the quick responce i dont think my ISP would try to contact me 14 times in under 1 second
this to me looks like a real attack
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
after doing a who is on one of the IP i get
Organization: RIPE Network Coordination Centre (RIPE)
this is NOT my ISP ....
- Mark as New
- Bookmark
- Subscribe
- Permalink
@handy142 wrote:after doing a who is on one of the IP i get
Organization: RIPE Network Coordination Centre (RIPE)this is NOT my ISP ....
Maybe not.
But nor is it the Russian mafia:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can we get back to the topic ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
All address filters have done is stopped the attacks from being logged, not the attacks themselves. If the DoS attack logs were bothering you, you could have turned them off rather than resorting to the laborious process of maintaining address filters by hand, which is an utterly losing battle. It's no different than trying to block phone numbers. Both phone numbers and IP addresses can be spoofed. You'll forever be playing whack-a-mole.
Trust your DGND3300 to defend itself without your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
But I could not longer continue due to reaching my limit
As for the time it takes to block these did attacks it's worth doing for the results I get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok, normally heres a good example of one "attack" (ive removed my IP from these)
Tue, 2017-01-17 03:09:16 - UDP Packet - Source:134.119.219.27,5445 - [DOS]
Tue, 2017-01-17 03:09:16 - UDP Packet - Source:134.119.219.27 - [PORT SCAN]
then i add that IP my my block list and then i get
Tue, 2017-01-24 15:04:19 - UDP Packet - Source:134.119.219.27,5327 - [Any(ALL) rule match]
in short this means they cant dos me again as ive blocked them
unfortunatly my modem can only block 108 IP's before it gets full i would like one that allows me more or unlimited blocked IP's
- Mark as New
- Bookmark
- Subscribe
- Permalink
Forgive me. I should have been clearer. We already know about the limited number of IP addresses you can block.
I should have said tell us the results that you get in terms of better performance when you block those addresses.
Does blocking them make your Internet go faster? Do you get a better browsing experience?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is not true. One other precious resource to be protected is your Internet connection. Someone can still take you down by flooding it. A block list can do nothing to stop that. All your block list has done has hidden the attack. It's the equivalent of putting blinders on. Functionally, nothing has changed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would agree with this type of attack is a flood attack designed to slow my connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The modem was already stopping the attacks. The address filters aren't buying you anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i think my modem wasnt filtering anything untill i started to block them the report as above shows my modem recived the request(s)
once i block thenm my modem would ignore the IP and not process that request
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's time to stop thinking that. Perhaps you don't realize that your DGND3300 has built-in firewall and NAT functions that block all unsolicited incoming traffic. Your modem is technically a combination modem and router.
Actually, that report is literally a log about your modem blocking those request(s). The modem was figuratively saying, "Hey, I'm letting you know that I identified a DoS attack from address A.B.C.D and blocked it."
Do you understand, now, why your address filters aren't buying you anything? The modem already did its job of blocking the request without your help.
michaelkenward wrote:
Does that mean that it is a waste of time looking for a device that allows a user to block an even bigger list of addresses?
In the context of preventing DoS attacks, yes, it's a waste of time. As I mentioned above, the built-in firewall and NAT components already prevent these attacks from reaching your home network.
I didn't mention this before, but there's also a pretty good chance that address filters will disable hardware acceleration, force the main CPU to handle all traffic and potentially slow down your Internet connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@TheEther wrote:I didn't mention this before, but there's also a pretty good chance that address filters will disable hardware acceleration, force the main CPU to handle all traffic and potentially slow down your Internet connection.
Oh dear. This gets more complicated by the minute.
Thanks for the tutorial. Very helpful.
- Mark as New
- Bookmark
- Subscribe
- Permalink
*facepalm* look can we get back to topic please ?
can you recomend a router that can do what ive asked or not ?
i dont care if its wack a mole, i am convinced what i am doing is the correct thing to do
please can you help me ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok this is how i see it
my modem recives a UDP packet from XXX.XXX.XXX.XX: and logs it
it has to process the request. as the request is deemed by my router as a "valid" request.
As this can be one or many requests (flood attack) which can slow down or even stop a connection (DoS)
since i dont belive my modem does not stop the request (yet) but logs the fact this has happend.
i then add the IP to a block rule effectivly stopping the modem processing any requests from that IP.
side thought ....
i wonder if its 109 active rules or 109 in total ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let's suppose your modem/router receives a UDP packet with source address x.x.x.x and source port y to destination address m.m.m.m and destination port n.
To process it, your modem/router looks up its NAT table for an existing session that matches x.x.x.x, y and n. If no session exists, then it checks for any port forwarding entries that match n. If none exist, then it checks if a DMZ is configured. If not, it drops the packet.
Most of this work is highly optimized and is really no sweat for the modem/router to perform. Adding address filters is not only going to save an immaterial amount of processing but it will slow down the entire packet processing pipeline because the modem/router will be forced to disable hardware acceleration and pass all packets through the CPU for deep packet inspection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
thats not how i see it useing one packet as example (rember this will be part of a flood acctack so there is more then one to process)
-1- my modem recives the packet from x.x.x.x - checks the firewall rules first and its not on a block list
- 2- the packet is recocised as a requst to my modem
-3- the modem would then process the request (not shure if a responce would be sent back but lets say no for now)
-------------------------------------------- if on list ----------------------------------------------------------------------------
-1a -my modem recives the packet from x.x.x.x - checks the firewall rules first and IS on a block list
-2b- the packet would not have to be processed as its on the list and the request is ignored
thats how i see it (roughly)
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's not really a request. A request implies that the packet is something that modem would send a response to. Most packets that are not dropped by the modem will transit through to a device on the home network.
It would process it in the manner I described (i.e. NAT lookup, port forwarding and DMZ check). The end result is same as your case below with the block list; the packet is dropped by the modem and is not sent to your home network.
Because a block list is present, the modem redirects the packet to the slower, non-optimized packet processing path. All packets, including good traffic, must go through this slower path. If no block list is present, the modem will process the packet much more efficiently.
In both cases, the packet is blocked by the modem. Do you now see why a block list has no added value here?
