Orbi WiFi 7 RBE973
Reply
Port Forwarding issue on Netgear D7000v2
Sean44
Follower
I have a weird problem. From my Netgear D7000v2 router (Firmware: V1.0.0.51_1.0.1) I have been trying to do port forwarding on certain ports. Previously I used to do the same thing from my BT router without any problem (quite experienced with the process).
After DynDNS and port forwarding Whatever devices are connected to my Netgear Router (Home Wifi) can not access to the services but I can access those services from the internet (not from my home wifi).
Anyone got any clue what I might have done wrong? Or is it a fault with the Router/Firmware? And I am sure it's got nothing to do with Firewall because its working from outside of the local network and I tried turning my server firewall off. FYI I do not have any intention to flash the router with DDWRT.
Appreciate any help.
Thanks
Model: Dual Band
Message 1 of 2
antinode
Guru
Re: Port Forwarding issue on Netgear D7000v2
   Bought a Netgear D7000v2?
      https://community.netgear.com/t5/x/x/m-p/1690769
And follow the links.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1094 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
