× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 2 replies
  • 3865 views
  • 0 kudos
  • 3 in conversation
Announcements
Reply
Highlighted
Follower
Power light orange and internet light red D6200
After attempting an upgrade over wifi my D6200 router won't show up on my computer and has a red Internet light and an orange power light. Ive tried powering off and a reset but nothing has worked. Any assistance will be appreciated.
Message 1 of 3
Highlighted
Retired_Member
Not applicable
Re: Power light orange and internet light red D6200
Check the manual ..........troubleshooting using LEDS is a good place to start
Message 2 of 3
Highlighted
Prodigy
Rule #1 when updating a router you don't do it over wifi. That's the biggest No No. The thing that can happen is that you can brick your router. I'm not sure about that model of netgear but some do allow a recovery when flashing to a newer firmware. If there isn't you can always try the TFTP method. Look on youtube on "how to debrick a router" Use the tftp2 software and follow the instructions and you just might be able to revive you router.
Message 3 of 3
