- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
PowerLine Internet not identified
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have a Fritz 510E Powerline set (It's a German company)
I was using it for around 3 months. My ethernet connection was working perfectly.
One day I loaded my pc and ethernet would not connect, the reason would be "unidentified network"
I have tried all of the steps I could find on the internet from netsh renew to manually changing IPv4 and resetting. It wouldn't work.
then I just kept on using wi-fi. Recently i remembered about having the powerline so i decided to give it another try and fix it.
I thought that the cable could've been the problem so I bought a new one, but it didn't fix. At the time I was using a extension socket, and somebody told me to allocate the adapter its prorer socket, that's what I did and at first it would work on and off. I would have connection for 5 - 10 minutes and then it would not work again, and then it started working just fine, I used it for about a week or slighlty more, and the same problem occurred. Now every time I load the pc, I have the "Unidentified Network" I have tried the same steps as last time, but it didn't help.
Hope to find some help here.
Thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
