Reply
Problems with wifi
Roomars
Problems with wifi
Good morning,
I ask you update firmware because my Internet Wireless 2.4Ghz is crashed very often, and last once a day i have to restart my router to get it started again.
I have read throug your discussions in your forum that there is a beta firmware update that fixes the problem.
thanks. regards
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 8
Roomars
Re: Problems with wifi with DS7800 Nigtthaws
I need help
@Roomars wrote:
Good morning,
thanks. regards
Message 2 of 8
Greetings,
All Downloads for the D7800 are here:
https://www.netgear.com/support/product/D7800.aspx#download
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 3 of 8
Roomars
@shadowsports wrote:
Greetings,
I already have the latest firmware version, but the problem has gotten worse. now I have to restart the modem every day, it is not possible to continue like this.
Message 4 of 8
Roomars
I need help, i restart my router everyday
Message 5 of 8
"Crashes" could mean many things.
What are the symptoms? What error messages do you see?
The wifi LED goes off? Every wifi devices loses a connection? Things will not connect?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 6 of 8
Roomars
The symptoms are disconnection of all connected devices with 2.4Ghz Wi-Fi, while 5Ghz and LAN continue to work regularly.
The connected devices remain connected to the network but remain blocked and do not browse, while if I try to disconnect and reconnect them it simply says "unable to access the network"
A simple restart of the modem and all devices connect automatically.
Message 7 of 8
OK. So you don't have to reset to get things back, just restart.
After you installed the new firmware, did you factory reset (not just restart) the modem/router?
If you did and you still see problems, then you could try using earlier firmware. Latest is not always greatest.
Just another user.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 534 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
