- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R700 nighthawlk intermittently disconnecting WIFI
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had this new router for several months now, and several times a day the WIFI randomly decides to stop working. I have troubleshooted on line and the only things I have found as a solution is to update the firmware. I have clicked on the check for updates button and it said it's up to date. I am still having issues, please can someone give me another solution to this persistent issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R700 nighthawlk intermittently disconnecting WIFI
What do you see when this happens?
The wifi LEDs go off? The Internet doesn't work? Wifi clients will not connect to the wifi?
What leads you to that conclusion?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
This is the most reliable way to update firmware:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Check the section in the manual on updating the firmware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
What device are we talking about here? Your subject says R700, which could be one of several things, but your footer says XR700, which is a radically different that has nothing mush to do with any "R700" device you might have in mind.
Whichever device you have, it probably isn;t the "modem/router" covered by this section of the community.
You have posted your message in the section of this community given over to Cable Modems, Routers and DSL Modems. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk WiFi Routers
if you own an R700X or here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
if it is an XR700.
Sorry reply this is so long, it is a result of having incomplete details of what is going on at your end.
