- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000
> I recently put my isp cable/modem in bridge mode with my nighthawk
> r700 do I need to put the nighthawk in bridge mode as well
Presumably, you would want one router somewhere. If the
(unspecified) "my isp cable/modem" is a bridge, then the R7000 should be
a router.
> After I did bridge mode it shows my ip is like 10.0.01 instead of like
> 192.168 something
After you "did bridge mode" to what? Which "my ip"? Some LAN IP
address? The router's WAN IP address? The WAN IP address of your "my
isp cable/modem"?
The R7000 will normally use LAN addresses in the 192.168.1.* subnet,
but if its WAN interface gets an address like that from the next gizmo
up the line, then it will select some other subnet for its LAN, to avoid
conflict with the WAN subnet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000
@xAKB wrote:
After I did bridge mode it shows my ip is like 10.0.01 instead of like 192.168 something
That is really just an alternative to 192.168 something. It is another local IP address.
It sometimes happens when you put a modem and router together and start things in an order that Netgear disapproves of.
If it is important, reset things and start from scratch and you may get something that you recognise.
There is support material, including a manual, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
The Installation Guide is probably the simplest thing to follow.
Just put the modem in bridge mode. You want the router to be in charge.
Maybe things are working just fine. In which case, you might want to leave them alone.
