- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyCLOUD failed to upload any files to USB device connected to the router D7000 Connection problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi to everybody,
from any PC (windown or MC) connected on LAN or WI-FI with any USB Device (8gb pen drive or 500 GB toshiba hard drive) when I copy a file from the pc to the direcory of the USB device connected to the router the trasfef start and then stop giving the following error:
FAILED TO UPLOAD
CONNECTION PROBLEM
thank you to anyboby that will replay.
Andrea
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyCLOUD failed to upload any files to USB device connected to the router D7000 Connection pro
Hello ab91
What router device are you using?did you make change in Advance settings of "Readyshare" page?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Deniro
The router is a NETGEAR D7000.
I set up the readyshare page as for instruction.
The USB device is properly showed on the ReadyCLOUD or ReadySHARE utilies.
The only problem is the transfer of the files.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!we've already noticed that ReadyCLOUD D7000 device may not work with ReadyCLOUD utility very well,I will send issue request to Nighthawk team to investigate the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello ab91,
I will be moving your post to Nighthawk board to get the right community members.
Welcome to the community!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi JennC
thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear JennC,
the problem is the compatibility between Windows XP - Router - ReadyCloud
I installed on the same PC windows 7 and everything works properly.
Thank you for your help.
Best regards.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello ab91
This is a known issue with the D7000 readyshare I have already sent it to engineers to find a correction I have no ETA on when this will be fixed.
DarrenM
