Orbi WiFi 7 RBE973
Reply
Recursive routing detected error in OpenVPN
DeclanM25
Follower
Hi,
When i try to connect to my VPN on the netgear using OpenVPN the initiation sequece finishes and connected however i get a flood of recursive routing detected. Can anyone help me fix this issue?
Sun Feb 23 12:10:39 2020 Recursive routing detected, drop tun packet to [AF_INET]XXX.XXX.XXX.XXX:443
Sun Feb 23 12:10:42 2020 Recursive routing detected, drop tun packet to [AF_INET]XXX.XXX.XXX.XXX:443
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 2
reedededge
Initiate
Re: Recursive routing detected error in OpenVPN
We have found the best solution for the recursive routing flood is to modify the client config as follows:
comment out "nobind" so the line looks like this instead:
#nobind
then add --local IP line to config. If you're device does not have a static ip, use ipconfig from CMD window to retrieve it (Windows). So you add this line
local <your device's local IP>
We also tried the remedy of using an older version of OpenVPN client but that did not solve our issue.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4301 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
