- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Remote Desktop Issue & enable ping (DGN1000V3)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dears,
I haver netgear router adsl and have static wan ip , can not use remote desktop outside internal network and can not ping, and when create firewall rule RDP need ip from internal network not outside it (need same subnet) , please help me to solve it urgent case
Router model : DGN 1000v3
note: Respond to Ping on Internet port is enable
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Remote Desktop Issue & enable ping (DGN1000V3)
Your problem description was unclear. RDP uses TCP port 3389, so you should set up a port forwarding rule for that port.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rule created and and still face problem and can not ping
inbound rule need IP from same subnet
more than one face same problem please help me
if change frameware to another framware , will solve or not
- Mark as New
- Bookmark
- Subscribe
- Permalink
For example, if your home subnet is 192.168.1.x and your computer has IP address 192.168.1.5, then the port forwarding rule needs to point to 192.168.1.5.
What IP address address were you entering? Your static WAN IP address?
- Mark as New
- Bookmark
- Subscribe
- Permalink
