Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Repeater with DGND36700 dropping out
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-06
10:39 PM
2012-04-06
10:39 PM
I have a WNDR4000 and a DGND3700 that I am tring to connect via the WDS or Wireless Repeating Function. I am using the 2.4Ghz band, and have the SSD, Channel and Security (Completely off while I try and sort this out!) both set the same, and the correct MAC addresses in each router. And it works! For 5 minutes, and then I need to turn off the wireless on the WNDR4000 and turn it back on for another 5 minutes.
So whats the deal? Is WDS just broken? Cant I use another method?
Next question: Whats the most secure way of doing this? I can only use WEP with WDS? Whats this crazy talk?? Multiple iPhones, Laptops, Media boxes etc connect to the network so it’s a bit hard to lock down MAC addresses.
Message 1 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-07
08:33 AM
2012-04-07
08:33 AM
Re: Repeater with DGND36700 dropping out
http://vpncasestudy.com/download/WDS/WDS_Concept.pdf
If you read thread all the reapter question is repeated with same answer
You can ONLY use WEP or no encryption
If you want most security. USE EXTENDER wn2500rpt,wn2000rpt,wn3000rp
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-09
02:12 AM
2012-04-09
02:12 AM
Hey June.
Yep, I know thats a bit of an issue. But it still dosnt explain the dropouts of the extender after 5 minues (or less. Usually less. )
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-09
04:24 AM
2012-04-09
04:24 AM
Shorten distance
Repeating device must located between a-b point
B point be trouble signal allocation
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-20
05:02 AM
2012-04-20
05:02 AM
OK, so the result of this was that the WNDR4000 needs to have the Firmware updated to eliminate the issue.
Connect the WNDR4000 and DGND3700 on the 5GHz at 54mbps and use WEP. Hide the SSD.
Use the 2.4Ghz as normal, and you can call it what you like! Most devices are still only using 2.4Ghz, so it should be all good to dedicate the 5Ghz to the Bridge.
Sorted!!
Sorted!!
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-20
06:05 AM
2012-04-20
06:05 AM
you will be surprised that many of new laptops/desktop are dual band capable so nosey person can still get down to it ..
it is your network so whatever you make decision is the final. 🙂
Message 6 of 6
Announcements
