- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Reverse from AP mode to Default
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was using my netgear x4s d7800 in ap mode for a while and now I am trying to reverse it back to default but was unsuccessful.
I stuck a pin in the reset button and hooked up all the cables appropriately however cannot seem to configure the unit.
After I click the prompt to automatically detect my settings I get stuck on a screen that says "wizard is performing quick scan of your PVC/protocol; please wait" after more than 20 mins of waiting I was still stuck on this screen and could not progress.
The DSL/Internet light is red (internet connection undetected) and can't seem to get it to turn white.
Firmware V1.0.1.10
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Reverse from AP mode to Default
Can you access the modem's controls in the browser?
Can you connect through this:
The manual is here:
D7800 | Product | Support | NETGEAR
If you can get into that, you should be able to reverse the steps on page 253.
Maybe you have done all that. You don't say.
If you are using the setup wizard and that is what is failing, then try doing it manually. That's in the manual too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
can you list the settings that i would need to enter manually?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The manual says that to get it to get into AP mode you:
- ADVANCED > Advanced Setup > Router / AP Mode.
The Router / AP Mode page displays. - Select the AP Mode radio button.
My guess is that you just deselect the AP Mode radio button.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i cant log in to the router settings whilst it is in AP mode therefore i click the reset button on the modem so its not really reversing im starting from scratch again but my modem isnt detecting an internet connection.
