- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SKYQ won't connect to internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had a new SKY Q fitted only to be told that the new D7800 router i had was not compatable with SKY Q and it would not allow it to connect to the internet. Surely this can't be correct, i have just looked for a firmware update but there isn't one, and SKYQ finds network fin eand connects but then states No Internet connection. Help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SKYQ won't connect to internet
D7800 or R7800?
Your message says one, but the footer says something else.
D7800 is a modem/router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is a D7800 NightHawk AC2600modem/router - doesn’t appear on the drop down.
Apologies i saw 2600 and failed to see R and not D.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK. You have a modem.
What is the Sky box? A modem?
What is your Internet? Cable? DSL?
If Sky supplied the modem, you need to set the D7800 as a router. That means connecting your modem to the Internet (Red) socket on the back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, SKY is the major UK satellite broadcaster. SKYQ is their latest top set box, allows recording 5-6 shows etc and has mini boxes to other parts of the house that work on a closed mesh set-up.
its not a modem and requires either a WIFI OR wired broadband connection, i’ve Tried both and it connects to the router but not the internet.
Engineer that installed, stated it was a Netgear issue but i that didn’t seem right given the relative age and spec of the nighthawk.
interestingly the SKYQ box isn’t locating the 5G and i wondered if its possible to manually configure this? There is an option on set-up but unsure what those settings are likely to be.
Apologies for the ramble but any help gratefully recd.
Thanks
alan
@michaelkenward wrote:OK. You have a modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know what Sky is. Part of the Murdochs' evil empire.
My question is about the SKY Q box. I couldn't find anything about it.
If it comes with a LAN port, then you should be able to plug that into your modem/router.
In general, it is better to hard wire as much of the network as possible.
Does the SKYQ actually work with 5GHz? A lot of wifi stuff doesn't. If not, then SKYQ won't see it.
Where is this option on setup? The modem, or the SKYQ?
As you have the D7800, I assume that you are getting your Internet from someone else.
Some of those TV services lock you into their hardware. But not knowing anything about the SKY Q, I am left guessing.
I suspect that the Sky "engineer" doesn't have a clue, which is why they said that the D7800 is not compatible. Much easier to pass the buck than to deal with the issue.
There won't be many Sky users on this forum – did you search? – so your best bet might be to check out a Sky users' forum. That certainly works for BT customewrs, where the user to user support is often better than BT can muster.
Indeed, if BT is your Internet service provider you could try there:
Home - BTCare Community Forums
Then again, it took me fiver seconds to user a search engine to find this:
Getting a Netgear D7800 Nighthawk Router to work as a replacement for my Sagemcom F@ST2504n
As I said, the Sky forum is probably your best bet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Sky Q, installed for 'free' in November 2017. I too am using a Netgear d7800. My Sky Q box and Sky Q mini box have no issue connecting with my Netgear d7800 nor does it have any problem conencting to the internet. The Sky Q box doesn't connect to third party (ie non Sky broadband routers) via 5GHz channel, it reserves its own 5 GHz channel for its Sky mesh which is what it uses to connect with other Sky devices, eg Sky Q mini box or Sky broadband routers.
The Sky Q box connects to the D7800 (and any other non Sky routers) via the 2.4GHz channel or via LAN wired connection. So for anyone doing their hardest to force it to use the 5GHz channel are wasting their time!
- Mark as New
- Bookmark
- Subscribe
- Permalink
For the sake of anyone else who drops in on this conversation, note that the D7800 is a modem/router. This means that when used with other network hardware it can cause conflicts. For example, if your Internet service provider has its own modem/router, it may be necessary to tweak either that or the D7800.
