- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Samsung 7500 smart tv to wireless n900 router
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Samsung 7500 smart tv to wireless n900 router
You mean your TV is unable to see the SSID? You'll have to set up the TV again since you replaced the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Bobps47 Imagine your TV just like connecting your tablet or your laptop to the wireless network.
Do you see the wireless name that your router is broadcasting for you to connect to the Internet?
If yes, just go ahead and connect to it and input the wireless security if you have it enabled.
If you're not able to connect, then it could be a distance problem or interference.
If that's the case then you may want to relocate the location of the TV to have a better signal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You mean TV is unable to detect the SSID? Is TV dual band capable? On remote chance TV is too far from router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try to make the TV closer to the router.
If it still the same, get more assistance from Samsung.
Have them realize that your network is ok except for the TV.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the TV WiFi is definitely enabled, only way to prove is moving the TV set or router closer each other to test the theory. Aother question is did it work in the past?
