- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Seeking Replacement for DG834GV v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been using the DG834GV v2 with perfect results for several years. Our home phones are analogue, and connect to one of the two RJ-11 phone ports on the unit to provide VOIP operation with auto-fallback to PSTN. Sustained file download speed is typically 1.8 to 2.2 MB per second.
The DG834GV v2 has the following six key features in its single hardware package: ADSL2+ Modem, Router, Wired LAN Switch, Wireless Access Point, Voice-over-IP and SPI Double Firewall.
I now wish to have a QoS feature to assign a minimum bandwidth to the VOIP service for call quality. The DG834GV v2 does not have QoS.
Q. Is there an equivalent single unit available today which has the same six key features of the DG834GV v2 as well as the QoS feature?. If not, can I achieve what I need with two hardware units?
Thanks for any advice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Seeking Replacement for DG834GV v2
Hello Kubota
We do not have any newer modems that also have phone hookup on them but you may want to look into our Nighthawk series for QOS if your still wanting that feature.
DarrenM
