- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Software removal failure
- Mark as New
- Bookmark
- Subscribe
- Permalink
The computer this was attached to has been hard-wired into the network and the adapter is no longer needed.
Attempted removal today and got to the pop-up stating to remove the adapter from the computer. The Next link did nothing.
I tried reinstalling the software and reconnecting the adapter and starting again = same results. I can never get past this pop-up. It's still there after several minutes, and can only be stopped via Task Manager.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Software removal failure
> The computer this was attached to [...]
The non-psychics in your audience might not get much from that
non-description.
> Model: A6210|AC1200 High Gain WiFi USB Adapter
There's a more appropriate forum for such devices than this "DSL
Modems & Routers" forum:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please allow me to apologize to the "non-psychotics" in my audience.
I thought my description was pretty concise. What, in your opinion, was lacking?
Or do you recommend I move on and post this in that link you provided?
myself
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] What, in your opinion, was lacking?
"The computer" runs what? Some version of Windows? (I suppose that
"Task Manager" might have suggested that to an alert reader.) Does this
software have a version?
"Attempted removal [...]" How? What, exactly, did you do?
I'd guess that you might find more relevant information there,
perhaps even someone with a similar problem and/or solution. You could
try to contact a moderator to get this thread moved, but re-posting
could be simpler.
No need, and, in any case, I may not qualify as non-psychotic.
