- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Telstra Gateway + Nighthawk AC3200 Tri-Band WiFi Router or Nighthawk X4S VDSL/ADSL Modem Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just wanted the community's opinion on whether I would be better off using a Telstra Gateway as a modem with a Nighthawk AC3200 Tri-Band WiFi Router or if I would just be better off using a Nighthawk X4S VDSL/ADSL Modem Router?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Telstra Gateway + Nighthawk AC3200 Tri-Band WiFi Router or Nighthawk X4S VDSL/ADSL Modem Router
Hello LeoElite
Either way is good whatever is easier for you to do.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Doesn't the Telstra Gateway provide VoIP services too?
What will you use for telephony if you eliminate the Telstra decice?
Umm ... but I am assuming you have an NBN connection ... if not this is probably irrelevant.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I gave Mat Hammer from Netgear a call and he has suggested to use the Telstra Gateway as the modem for VoIP purposes and to actually set the Nighthawk X4S VDSL/ADSL Modem Router as a router only. Main reason for that was that the X4S has newer hardware than the X6. The only thing that the X6 has that is better is the Tri-Band technology.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@LeoElite wrote:I gave Mat Hammer from Netgear a call and he has suggested to use the Telstra Gateway as the modem for VoIP purposes and to actually set the Nighthawk X4S VDSL/ADSL Modem Router as a router only. Main reason for that was that the X4S has newer hardware than the X6. The only thing that the X6 has that is better is the Tri-Band technology.
You mean, use it as an access point and disable the wireless on the Telstra Gateway, right?
That's certainly one way to do it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, exactly right. 🙂
