- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to login to router using web browser AND GENIE
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello team,
Hope all are well
I recently hard wired my pc to my router.
I am completely unable to login to the router now that it is hardwired.
It is using ipv6 i believe as my domain address is fe80...
I have reset all network settings, reset the router, fresh install of genie, disabled firewalls and no virus software.
Internet is working great, but not able to access the router in any way using any ip address in any web browser or in the genie app.
Help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to login to router using web browser AND GENIE
What actual router do you have?
What modem/gateway is it connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
r7000 Nighthawk
i have Consolidated Communications Fiber internet
edit: the router is connected directly to the line coming from the pole basically. it runs through some battery backup thing first
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you put your r7000 in access point mode?
what actual ONT is it connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No I didnt put it in access point mode.
I dont know what ONT its connected to.
edit: Allied Telesis is the battery backup box
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can access the router through the nighthawk app on my phone if that helps, and it is not showing my desktop computer as being connected
- Mark as New
- Bookmark
- Subscribe
- Permalink
Allied Telesis is a brand. there should be a model on it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model: DUPS-1232GI
The internet is functioning fine on the pc in question, as well as through WIFI. the problem is the light on the router for the pc is not coming on, the router isnt recognizing i have a pc hooked up, and i cant access the router from the pc
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] the problem is the light on the router for the pc is not coming
> on, [...]
Do you mean the port-status LED for the LAN Ethernet port where
you've plugged in one end of the Ethernet cable whose other end is
connected to your (unspecified) "the pc"?
All LAN Ethernet ports on the router behave the same?
You've tested/swapped the Ethernet cable?
Your (unspecified) "the pc" works with some other router, or some
other client device also fails when connected to the R7000?
> [...] the router isnt recognizing i have a pc hooked up, [...]
"recognizing"? A vague description of what does _not_ happen is less
useful than a clear description of what _does_ happen.
> [...] and i cant access the router from the pc
"cant" is a word, different from "can't".
"can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
What does Windows have to say about that Ethernet interface?
"66.205.131.180" is a public IP address. Your (unspecified) "the pc"
might get that if it were connected directly to your ONT; it should not
get that if it is connected to a LAN port on the R7000...
...unless you had done that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes the port status indicator is doing nothing while the my PC is connected to the router via cable.
I have a switch also hooked up that lights up the router light, and accesses the internet
I cant swap the ethernet cable because it runs under my house. but i can try to move the computer out there and connect it.
when i go into the router page through my phone it does not show the PC, but it does show the rest of the devices on wifi and from the switch.
I have input 192.168.1.1, 192.168.0.1, i have tried the Fe80 number in [] and nothing.
BUT the internet works fine on the pc.
When i use netgear genie on this pc, it cant login to the router, but it shows only the pc as "desktop-
when i ping the 192.168.1.1 from my PC it says request timed out.
I can login perfectly from my iphone using wifi obviously through 192.168.1.1 in safari
