Reply
Unable to register d7800 as already registered
sooty_after60
Hi
I bought the D7800 router and am having problems setting it up. So I registered so I could use Netgear community. However after not getting any further, I decided I wanted to try the 90 day support offered by Netgear. However I can't register my product as the system is having problems with my email/password combination. I did try the email/password combination I used to register for Netgear community but that was also having problems. What would you advise? Many thanks.
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 2
Guru
Re: Unable to register d7800 as already registered
Please post about this in the DSL modem forum:
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
You'll need to contact NG support about this.
Good Luck.
@sooty_after60 wrote:
Hi
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 269 views
  • 0 kudos
  • 2 in conversation
Announcements
