- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Using routed IP on D6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been allocated a batch of 16 IP address for home and have just bought a D6400 with the hope that it can do routed IP networking. i.e., the gateway for my network is the router IP address and the remainder of the routable IP addresses can be allocated as I need to within the network.
Has anybody been able to set his up? Or can anyone confirm that it can't be done, and I'll stop trying...!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately, the D6400 does not have support for a block of IP addresses. If your ISP gave you a gateway, then it will likely have that support.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Using routed IP on D6400
Thanks - I suspected that was the case. I'll need to find another with support.
The one from the ISP support a block of IPs, but has no firewall capability, so it's very exposed - hence my search for a replacement.
