× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 1 reply
  • 65 views
  • 0 kudos
  • 2 in conversation
Announcements
Reply
Highlighted
Follower
WIFI ROUTER CONNECTION
How do I change network name and password. I have had wifi before but discontinued service. I have recently restarted services but for which I can see the network name but the password associated it doesnt work.
Model: D6100|AC1200 Wifi DSL Modem Router
Message 1 of 2
Highlighted
Re: WIFI ROUTER CONNECTION
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find the documentation for your hardware.
If you are recommissioning some old stuff you had lying around, or switching to a different ISP, it is a good idea to start from scratch. Reset the D6100 Modem Router to factory defaults and go through the setup process laid out in the manual.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
