- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi 2.4ghz D700v2 connection problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying to connect to the 2.4ghz wifi network on my D700v2 and I keep getting password incorrect even though it’s the same as the 5ghz wifi password?
Any idea what’s causing it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi 2.4ghz D700v2 connection problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it just one device causing the issue or every device that tries to connect to the 2.4?
and just because I get misunderstood, did you try changing the password on the 2.4 to something else?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried telling the wifi client to forget that it ever connected to the D7000v2?
Then set up the connection from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How many devices are connected to the 2.4 band? I have found that on my Range Extender I can only attach 18 devices. If I then try to connect with my iPhoneX it gives me a password error. If I drop one or more of those devices, I can log in.
Other possibility. If you are using an iPhone to connect, there is a weird wrong password issue that sometimes can be resolved by going to reset and resetting your network connections (which does, BTW, delete all of your stored passwords for all the networks you log in to).
Anyway, just a couple of thoughts. Not sure if either of them are useful.
Dave
