- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi Connection of Wireless N300 Modem Router DGN 2200
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Could some one please help me to safely connect my old Netgear router to my wirless network.
I use Sky broadband and the supplied router is pretty poor however, I have an old Netgear router which I wish to use as a network booster, the router works fine connected to a wired feed and does boost the wireless signal but the equipment had a factory re-set some while ago so the router has no security set up.
I wish to set up the security on the router in order to avoid any issues in the future, as I said earlier the router does exactly what I want it to do but has no security settings and I am unable to find a way of doing this.
BolehillBoy
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi Connection of Wireless N300 Modem Router DGN 2200
If ths is conneted to Sky router log into sky router and check attached device list for Dgn's assigned IP and then use that IP to login to it.
