Orbi WiFi 7 RBE973
Reply
X4s
Pmiksza
Follower
X4s
I cant connect to my x4s.
Its not listed on netgear nighthawk.password and admin dont work.no one can help me .
Bought second hand from friend, i know it works.
Help.
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 2
Guru
Re: X4s
Do you have the D7800?
What firmware is on it?
if you bought it secondhand, did you factory reset it? push and hold reset for 7-15 seconds while its powered on.
That'll get it back to factory.
then you can just follow the install guides.
they can be found at netgear.com/support/    type in you model number and it'll take you to your support site
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 552 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
