Reply
adapter:en1 failure on D6400
Allan1965
Hi
My interenet was upgraded from ASDL to VSDL recently.  At the same time my moden stopped working.  When I tried to reboot it stopped with a meassage "Fix adapter:en1 failed".  What does this mean and what do I need to do to get my system up and running again.
Thanks
Model: D6400|AC1600 WiFi VDSL/ADSL Modem Router|802.11ac Dual Band Gigabit
Message 1 of 5
Re: adapter:en1 failure on D6400
Which ISP?
You probably need to find the details required to login to the VDSL service and to set up the D6400 accordingly. I'm on BT in the UK, it made the switch automatically.
A first move might be to run the setup wizard from scratch to see if it can automatically detect the Internet settings.
See page 42 of the manual:
>>> D6400 | Product | Support | NETGEAR <<<
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 5
charmaine
The dsl led is not a solid green. It blinks every so often.
Message 3 of 5
Here too.
It is just showing you that there is traffic. The fact that it is lit suggests that it is connected.
Did you get the login details you need? Have you managed to login to the browser interface?
Just another user.
Message 4 of 5
Allan1965
Hi
Been away for a few days.  Just went through the set-up wizard.  Had to manually input a couple of pieces of information but its working fine now.  Thanks a lot for your help.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1906 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
