Orbi WiFi 7 RBE973
Reply
can't connect my Nintendo Switch
sbs8307
Follower
I keep getting this error message 2110-2199 on my nintendo switch, how do I fix it?
Model: AC2400|Nighthawk AC2400 Smart WiFi Router
Message 1 of 2
Guru
Re: can't connect my Nintendo Switch
according to nintentdo:
How to fix error 2110-2000 through 2110-2899, 2110-1000 through 2110-1999
Wired:
  • Make sure that both ends of your Ethernet cable are securely connected.
  • Try a different Ethernet cable.
  • Restart your Switch by pressing the power button for 3 seconds.
    Restart your router and modem.
  • Connect using a different port on your router.
Wireless:
  • Restart your router and modem.
  • Make sure your Wi-Fi password is correct.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2088 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
