Reply
can't connect panasonic viera tv to wireless router
Lunchbox11
Follower
Just got the DG6200 - nearly everything connects to it - phone, iPad etc but I can't get the Panasonic Viera TV to connect. It used to be able to connect to my old Belkin router but not the Netgear. Have used the WPS Push method as well but TV simply can't find the router. 99% sure I've entered all the settings correctly. Any advice appreciated. Thanks
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: can't connect panasonic viera tv to wireless router
Hello Lunchbox11
Can the Tv see the wireless network but cant connect? or it cant see the wireless at all? if it can see the wireless but cant connect you may want to try and change your security type on your wireless the TV may only like to connect to a certain type of wireless security. The other thing you could try is to manual enter the IP address in the Tv. Hope to hear your feedback
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4331 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
