- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
d3600 firmware upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a couple of days ago upgraded my modem router firmware to 1.0.0.64
I found that all previous configurations have reverted to factory default
I am now also having many problems including
Each time the unit is rebooted I have to go through resetup
I am unable to change the configuration of the wifi settings ie ssid and passphrase
Is there a solution
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: d3600 firmware upgrade
Try to manually flash the firmware again. Perhaps it didn't work properly.
You may have to factory reset after the flash, but once is usually enough.
Find the manual and the firmware here:
>>>>> D3600 | Product | Support | NETGEAR <<<<<
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried re-installing the firmware but each time it fails.
I have also reset the unit to factory default and tried to install the firmware, but this also fails
I am using the file "D3600-V1.0.0.64_1.0.1.bin"
The message reads "Firmware Upgrade Failed.Please Check your File"
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Steve_darls wrote:I have tried re-installing the firmware but each time it fails.
Hmm.
Tried earlier firmware?
Retrieved another copy of the firmware just in case it got bust when you extracted it from the zip file?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have now re-downloaded back three firmware versions
I have gone back three firmware versions and all failed in the same way
I have also tried installing these same firmware versions from a different pc with the same result
- Mark as New
- Bookmark
- Subscribe
- Permalink
> 1.0.0.64
I know nothing, but this sounds familiar:
https://community.netgear.com/t5/x/x/m-p/1342278
After upgrade to version V1.0.0.64_1.0.1 D3600 loses all settings
on every reboot.
It's starting to smell like a (serious) bug.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello I have exactly the same issue, after upgrade to version V1.0.0.64_1.0.1 D3600 loses all settings on every reboot.
Any valid solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello separarto
Does this not happen on older firmware for you?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rif.: d3600 firmware upgrade
Same problem with FW 1.0.0.64_1.0.1: every time the power goes down, it reset himself to default settings.
And I have another issue: I can not upgrade to 1.0.0.65: if I try with auto, it stuck after download, and I have to reset to default settings with the small button on the rear of the modem; if I try with manual, it says that the .bin file is not valid.
Any suggestion, please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is no 1.0.0.64 on the website, so either it is a different model or it was such a disaster that Netgear removed it from the collective memory.
Try downloading the firmware again to see if that is any better.
If that fails then it may be down to drastic action, like using tftp:
How to upload firmware to a NETGEAR router using TFTP | Answer | NETGEAR Support
