- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
d6000 not starting up
- Mark as New
- Bookmark
- Subscribe
- Permalink
My D6000 was in the middle of a firmware upgrade when it lost power , now when booting up , only the power light comes on ...nothiung else
I have not been able to do a factory reset , it doesnt dfo anything , not can i connect to the device via lan cable...any ideas
Thanks
Peter
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: d6000 not starting up
> [...] only the power light comes on [...]
Solid? Flashing? You might be a candidate for the TFTP recovery
scheme. See, for example:
- Mark as New
- Bookmark
- Subscribe
- Permalink
As well as trying TFTP, you could try a more severe "recovery mode".
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, the power LED will flash white. This may not get any further, but it is something that Netgear's techies advise when play tricks with devices.
