- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
d6400 as ap block forwarding
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, i've set up the d6400 as ap after i've had a lot of problems with it as dsl router.
It works correctly now but it blocks every remote connection.
I've set up on my base router(tp-link firmware upgraded to last version) some port forwarding, and if i put some devices (NAS, camera) after the netgear, it won't work. If i put them directly connected to router then they will work.
On d6400 there are very few options when setting it as an ap, so I don't really know what to do...
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm really stupid, sorry.
I didn't change the gateway on the cameras, as they get static ip...
Sorry for your time!
Many thanks!! 🙂
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: d6400 as ap block forwarding
Did you enable AP Mode under ADVANCED > Advanced Setup > Wireless AP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rif.: d6400 as ap block forwarding
And found the page for forwarding, but either allowing or forwarding port doesn't work...
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's odd. In AP mode, its firewall should be disabled so nothing should be blocked.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think i will sell it on eBay...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why are you forwarding port 80 to the Netgear?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. You should set up your main router to forward those ports directly to the IP address of the camera. Don't forward it to the Netgear. As far as port forwarding is concerned, the Netgear should be transparent when it is in AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you ping the IP camera from a computer connected to the main router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Many thanks!! 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you found the problem. No eBay, today. 🙂
