- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
d7000v2 last firmware not to lose Blocked Services on reboot?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I purchased this router as I had used the previous version before and knew that it had the blocking / access features I wanted.
With the latest firmware V1.0.0.82_1.0.1 any rules set in Security > Blocked Services appear to be lost on reboot.
Have been back to V1.0.0.80 abnd V1.0.0.76 but these both show the same behaviour.
Have also done a factory reset with the .82 firmware but no improvement.
Does anyone know the last firmware version where Blocked Service settings were not lost on router reboot? Or am I missing something obvious?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
With more trial and error I think I have narrowed down the problem and got a work-around.
In Security > Block Services, if I choose the pre-defined "Any(TCP)" Service Type for my rule then the entry is not lost on reboot. If I choose the pre-defined "ALL" Service Type then the rule is lost on reboot. Any(TCP) will work for me and is retained on reboot so happily using that from here on.
Hopefully it's just me affected by this.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: d7000v2 last firmware not to lose Blocked Services on reboot?
First, you say !this router". The D7000v2 is a DSL modem/router is that what you have? Is it in modem/router mode?
I ask because someone else has been playing around with a modem/router in AP mode. That removes various features.
So, you can get to and change the settings but they don't stick?
Do they actually work if you don't reboot?
Any hint of wonky behaviour on the router's logs?
Sounds more like a bug than a change in the features. (These sometimes get moved around with different firmware.)
Any particular service causing grief?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes. D7000v2 modem/router. I have done a factory reset and just added ISP username and password so presume it's operating as modem/router. Internet access is fine.
Yes, I can change the settings in Security > Blocked Services and the specified single IP is added to the list at the foot of the page and blocked as expected. I'm selecting the preset ALL service from the drop down menu.
Nothing is recorded in the log when services are blocked, even though that option is selected in the Log settings.
When the modem/router is rebooted then the Security > Blocked Services list displays as empty. Can re-add etc. but that's not how I think it should work. Definitely a bug hence the question asking how far back in firmware versions I need to go to get one that works.
Would be great if someone else has the same modem/router and confirm they see the same behaviour.
Many thanks all,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes. With that detail we could chase Netgear for some sort of follow up.
Just another user.
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
User | Count |
4 | |
1 | |
1 | |
1 | |
1 |
