Orbi WiFi 7 RBE973
Reply
d7800, need to isolate one ethernet port so it has access to internet but not the rest of my network
Smitje1
Follower
Hi,
I now work from home and have been given a cisco meraki so that I can connect securely to the office network. However, I don't want the office IT security team to be able to look onto my network. Is there a way to isolate the ethernet port that the meraki is plugged into so that it has internet acces but no access to my network ?
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 2
antinode
Guru
Re: d7800, need to isolate one ethernet port so it has access to internet but not the rest of my net
> [...] have been given a cisco meraki [...]
   So far as I can tell, "cisco meraki" is a company/division/service,
not a gizmo.  What, exactly, were you given, and what, exactly, are you
supposed to do with it?
> [...] Is there a way to isolate the ethernet port that the meraki is
   I know of no way to do anything special with one of the LAN Ethernet
ports on a router like this.
   If your mystery gizmo does something like establish a VPN/tunnel
between itself and your "the office network", then it's not immediately
obvious that any remote user would be able to interact directly with
other devices on your LAN.  However, I know nothing about your mystery
gizmo and its actual capabilities, or what you're doing with it.
      https://meraki.cisco.com/
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 674 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
