- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
dg834g problem after reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi everybody,
i do need your help, I've got a Dg834g netgear router at home. Everything was working until when the Internet stop to work. Then I've press the button reset factory settings to try to make it work. I know now that was a mistake because when I want to go on internet the computer didn't see the connection and so I can't go on internet. I think I've loss my informations.
how can I re connect my internet ? Do you have any procedure to deal with it ?
thank you very much for your answer
eliott
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: dg834g problem after reset
Hello Eliott
Here is a article on how to set internet connection back up on a DSL modem you also may need to contact your ISP for some login info if you have lost that.
http://kb.netgear.com/app/answers/detail/a_id/120?cid=wmt_netgear_organic
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do we contact the ISP ? is there an number ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The ISP is the company that provides your internet service. There are 000s of them. Look on the bills they send you.
They will also have a website that should tell you the information you need to login to their system. You will have to feed the modem with the password and username they give you.
This isn't a Netgear issue.
