- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
firmware updates
- Mark as New
- Bookmark
- Subscribe
- Permalink
firmware updates
Hi Guys
I am having trouble trying to up date the latest firmware on my device i have tried multiple version and keep getting the same response it also constantly disconnecting is there a fix for tthis ??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: firmware updates
What response are you getting?
What FW is currently loaded?
Be sure to unpack the .zip file before uploading the actual FW.img file seen.
Try MS Edge or Firefox browsers.
Factory reset the router then setup from scratch then try to update manually:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Redturtleraph wrote:
It simply said it's the wrong file or it's corrupted or not the right type of file ? I've download it and un zipped it many times FW 1.0.1.68 is as high as it will.let me update too
That is the latest version.
https://www.netgear.com/support/product/D7800.aspx#download
so what version are you trying to install and where are you getting it from?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
forcing a firmware that isn't for that version of router will cause issues (if you can even get it to install).
Make sure you're installing the one for your version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wasn't able to load any of the updates when I tried to do so . So I left it as it was using the auto updates feature. But I still couldn't get it to stop crashing.
couldn't get what to stop crashing ?
the auto-update?
The router? If the router, what is all going on? Details help more than "crashing"
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
does everything drop? Just wireless devices? Or wired too?
Is the unit rebooting? (light shut off and it boots backup)
do device say, connected, no internet? Does the wifi itself stop broadcasting?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No it's the nighthawk X4S AC2600 Model D7800 ...
You are using it as a modem/router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
whats the d7800 connected to? A modem (if so what model) or dsl?
- Mark as New
- Bookmark
- Subscribe
- Permalink
