Orbi WiFi 7 RBE973
Reply
netgear d7000v2 stuck in modem mode
jayvoor
hi just got a new netgear d7000 v2 vdsl modem router
i put it in modem mode only to use a asus rt-ac56u for my hard drive films
as the netgear dont like hard drives some reason it crashes the menu
well the thing is how to i get in the setting to put it back in router mode
i tryed everything from 192.168.0.1 on wards no luck
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 3
Accepted Solutions
w3wilkes
Prodigy
Re: netgear d7000v2 stuck in modem mode
I have my d7000v2 in modem only mode also. I noted that the manual only tells you how to get into modem only, not how to get out. Since mine is working fine with another router I've not tried to go back. Have you tried a factory reset? Seems like if you're in modem only you don't have anything to loose doing the factory reset. Instructions to reset are on page 159 of the manual.
Message 2 of 3
All Replies
w3wilkes
Prodigy
Message 2 of 3
jayvoor
Yes factory reset is the only way back .lease I know now
Cheers I back to modem router now
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1887 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
