- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
netgear
- Mark as New
- Bookmark
- Subscribe
- Permalink
netgear
Hi, can you give me some steps on setting up my netgear d6400 to my NBN hfc connection ? Ive done all settings correctly but still not authenticating ? Ive set it to PTM> VDSL2
VLAN is set to 2 as ISP provided > selected must use ethernet wan. what else is missing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: netgear
Did you find this in your quest for a solution?
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
They seem to have updated this recently.
It says that users with Hybrid Fiber-Coaxial (HFC) have to use "a cable modem or gateway to connect them to the Internet".
In this case, you may have to connect the device to the WAN/Internet socket on the back of the D6400.
There are quite a few messages around here about NBN. The problem is that this service comes in different flavours. So what works with your D6400 might not work with someone else's.
