Orbi WiFi 7 RBE973
Reply
nighthawk d7000 router
Roddaz
Follower
The App doesn't recognise this router
my laptop doesn't have an ethernet port
how else can i update the firmware please
Cheers
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 3
antinode
Guru
Re: nighthawk d7000 router
   D7000[v1] or D7000v2?  Look for "Model" on the product label.
Firmware version?
   _Which_ "The App"?
   USB-Ethernet adapters exist.  Other computers, with Ethernet ports,
exist.
   In principle, a wireless connection should work, but many people
believe that an Ethernet connection is less likely to fail.
Message 2 of 3
You can use a browser on your laptop to access the browser graphical user interface (GUI).
Connect to the wifi from the modem/router and then aim a browser at the usual addresses:
192.168.0.1 should work for a modem/router, unless you have changed it.
Update following this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Wifi updates are a b it riskier than using a wired connection, but less so that they were. Probably easier then shelling out for extra widgets.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 648 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
