Reply
password for Netgear02
clandsteiner
Follower
I bought a phone, and to use internet I need my password. When ! got the router I was having problems hooking it up. So I had called and he had me use the password on the back of the unit. Well I tried that and my phone says authentication problem. How do I get my password to connect my wifi with my phone?????
Message 1 of 2
Re: password for Netgear02
It might help if you said which Netgear device this is.
Remember, the password for the modem, router or whatever it is, is not the same as the password for its wifi.
I assume that Netgear02 is the "SSID" that you see on the phone, the password that goes with that should be on the modem/router, but they may call it the "Network Key".
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4465 views
  • 0 kudos
  • 2 in conversation
Announcements
